E
E Offline
And again, if you do switch to the 73 SD fuel pump, you will need the 73 SD pump to carb fuel line as your current line will not reach the inlet on the 73 SD fuel pump as the resovoir hangs down MUCH lower on the SD pump (hence the reason it is less likely to run out of fuel at high RPMs).
Or you can always run a rubber line from the pump to carb but I DO NOT recommend this. NOT a good idea! Ask me how I know...
fuel line question Revvingup 02/09/11 04:13 AM
Re: fuel line question Firebob 02/09/11 05:31 AM
Re: fuel line question colorado68 02/09/11 06:33 AM
Re: fuel line question Revvingup 02/09/11 07:41 AM
Re: fuel line question colorado68 02/09/11 04:23 PM
Re: fuel line question rohrt 02/09/11 06:36 PM
Re: fuel line question Revvingup 02/09/11 07:45 PM
Re: fuel line question Firebob 02/10/11 04:01 AM
Re: fuel line question Earlybird 02/10/11 08:19 AM
Re: fuel line question Gus68 02/10/11 08:24 AM
Re: fuel line question Firebob 02/10/11 08:41 AM
Re: fuel line question Earlybird 02/10/11 09:01 AM
Re: fuel line question Firebob 02/10/11 04:26 PM
Re: fuel line question Revvingup 02/10/11 04:56 PM
Re: fuel line question Earlybird 02/10/11 05:31 PM
Re: fuel line question 4dabird 02/12/11 06:46 PM
Re: fuel line question 8point 02/12/11 09:32 PM
Re: fuel line question hokie1984 02/13/11 01:37 AM
Re: fuel line question Earlybird 02/13/11 04:31 PM
Re: fuel line question Earlybird 02/13/11 04:35 PM
Re: fuel line question 68problems 02/13/11 07:01 PM
Re: fuel line question Earlybird 02/13/11 09:56 PM
Re: fuel line question Liam68FB400 07/01/12 06:44 PM
