It's tricky with the wheel still on. You don't want to screw up the finish. But try taking a cutoff wheel and making an X cut in the top of the lugnut until you get to the stud, then you have to use a cold chisel and start peeling the lugnut back. You may not have to get it all the way as it will start to loosen up while you do this.
