Thanks. I have ports I can tap into right on the manifold. Is my vacuum advance source just manifold vacuum? Thanks again.
David
1. That will work 2. I wouldnt know. Some folks use ported some manifold for vac advance. If you check the port it's plugged into now with a vacuum gauge and have 0 vac at idle and then get a vac reading while revving it up to 2000 rpm, that would indicate a ported connection.
