The shape of the rally lugs where they make contact with the wheel are the same as standard lug nuts. If you have anything close to where the lug openings are enlarged that big, you have a real problem.
I'd say it's a wheel problem, not a lug nut problem. Jack up a wheel, take all the lug nuts off, then see how much play you have in any direction. With correct wheel openings, there shouldn't be much play at all.
Post some pictures of the wheel openings if you are not sure. See if they are ovaled out or worn.
