There are two power connections to the radio. Although you could check it out with a meter, I think the yellow should be the ACC (accessory +12) that will power up the radio when the key is ON or ACC. The grey is probably the radio light that will tie into the vehicle lights (I don't recall if the radio is on rheostat controlled 0-12v or solid 12v.) Again, check the wires with a voltmeter.
