I had leaks around the bumper bolts, also if you lift the rubber gasket areound the trunk opening. theres place where 3 pieces of metal goes together at the rear corners , abv tail ligyhts...on mine , and several others had it too, there was a small pinhole uNDER the rubber where it would leak in , an area where the three pices didnt quite close up...
