250 OHC 6 Oil pressure
Re: 250 OHC 6 Oil pressure
Kelly Myles
256601
08/18/12
02:17 PM
Jun 2010
Earth
Sprint OHC 6
Sprint OHC 6
Jun 2010
Earth
the spring in the pressure regulator is bad or the regulator piston is stuck
best is to rebuild the pump otherwise remove the big nut from the back of the oil pump accessory drive unit and see it the piston falls out
if you cant get it to come out then you will be rebuilding it anyway
Subject
Posted By
Posted
Kelly Myles
08/18/12
05:02 AM
hokie1984
08/18/12
02:44 PM
Kelly Myles
08/18/12
04:47 PM
Sprint OHC 6
08/18/12
06:17 PM
Kelly Myles
08/18/12
09:43 PM
Sprint OHC 6
08/19/12
12:14 AM
Kelly Myles
08/19/12
02:31 AM
hokie1984
08/19/12
10:01 PM
maxepr
08/20/12
01:13 AM
Kelly Myles
08/23/12
03:17 AM
Sprint OHC 6
08/23/12
04:04 AM
hokie1984
08/23/12
03:20 PM
Switch to Flat Mode
0 members (), 391 guests, and 20 robots.
Highlander
