So as long as the two front J bolt holes are wider than the leaf spring you should be fine. Even if they are narrower than the bottom plate holes it shouldn't be a big deal. Looks like you need to feed the front J bolts into the bracket first and then the back ends into the bottom plate. You may have to "persuade" the back ones to go in a bit.
