There is one major issue that I highlighted in a post in the Hall of Fame:
You cannot mix and match lower control arms with subframes due to the location of the bump stop.
For FGF's: On '67 subframes, the bump stop is on the frame behind the coil spring, for '68 the bump stop is on the control arm behind the spring and for '69 the bump stop is on the control arm IN FRONT of the spring. You must have lower control arms that match your subframe or aftermarket types with multiple bump stop locations.
And early '67 F-Body subframes will not work on later Nova's as they are missing the 3rd radiator support bushing hole that the Nova's utilized (different from either F-body)
The info you got about Nova's is incorrect. In 1973, the Nova started using the 2nd Gen (70-81) F-Body subframe. So your good Nova's for interchange are only '68 - '72
