C
C Offline
Pickleforks work fine for many of these things. Obviously they require a hammer, which you stated you didn't want to use on your gearbox, which is probably smart...so a jaw puller was initially suggested.
Did you still have a question? I'm a little confused by this sequence of comments so-far as they seem to be going in a circle...and it seems the first response accurately answered your first question...plus you now have a hammer & pickle fork alternative suggestion.
removing center link from idler arm and pitman arm Cali1969 02/10/14 07:07 AM
Re: removing center link from idler arm and pitman arm salmon38 02/10/14 02:41 PM
Re: removing center link from idler arm and pitman arm Cali1969 02/10/14 04:12 PM
Re: removing center link from idler arm and pitman arm crazecars 02/10/14 09:47 PM
Re: removing center link from idler arm and pitman arm Cali1969 02/11/14 02:44 AM
Re: removing center link from idler arm and pitman arm Cali1969 02/11/14 02:45 AM
Re: removing center link from idler arm and pitman arm Cali1969 02/11/14 02:46 AM
Re: removing center link from idler arm and pitman arm Mushroombert 02/11/14 05:51 AM
Re: removing center link from idler arm and pitman arm Cali1969 02/11/14 12:33 PM
Re: removing center link from idler arm and pitman arm crazecars 02/11/14 10:18 PM
Re: removing center link from idler arm and pitman arm Cali1969 02/12/14 02:25 AM
Re: removing center link from idler arm and pitman arm crazecars 02/12/14 05:23 AM
Re: removing center link from idler arm and pitman arm hokie1984 02/16/14 12:57 AM
1 members (Rus), 985 guests, and 131 robots.
