R Offline
I would have to agree with just throw it in and drive it. If for no other reason then to get a base line of what you like or don't like with that cam but the dyno looks pretty good to me. I would not be too worried about what the cam specs said. looks like a heck of a flat torq curve. The duration numbers look right in line for a street cam in a 455. I would think with a good set of headers to complement the 110 lsa you will be pretty happy with it.
Like I said I ran a very similar combo in a heavy GP and it ran great. However the same motor and heads with a different intake, q-jet and LBM ran terrible.
I would do some testing with the two intakes since you have them. My best guess would be the Hurricane intake will give you more upper RPM HP since its a single plan and the RPM would give you a little more low end torq since its a dual plan. My just end up being personal preference on which one you like. The Hurricane intake has no exhaust cross over so it may be a little more cold blooded on starts but less likely to cause a gas boil over and hard starts.
400 with 455 crank combo help needed Paul M. 05/06/14 07:49 AM
Re: 400 with 455 crank combo help needed rohrt 05/06/14 07:20 PM
Re: 400 with 455 crank combo help needed Paul M. 05/07/14 02:43 AM
Re: 400 with 455 crank combo help needed Bluebird428 05/07/14 06:00 AM
Re: 400 with 455 crank combo help needed Paul M. 05/07/14 06:48 AM
Re: 400 with 455 crank combo help needed bigchief 05/07/14 07:48 AM
Re: 400 with 455 crank combo help needed rohrt 05/07/14 09:56 PM
0 members (), 1,611 guests, and 74 robots.
