The heads of the bolts have a rectangular strip of steel attached to them acting like a spring. (to hold them to the tail panel)
These are repopped, you should be able to find some picts online. Look under tail light bolts - 67 firebird.
There is a round hole in the tail panel with a horizontal slot. You press the head of the bolt through the hole, then slide horizontally in the slot. The spring holds them tight. Then you place the light assembly over the bolts and install the speed nuts over the housing.
67 tail light bolt installation tbarsch 07/17/14 10:45 PM
Re: 67 tail light bolt installation salmon38 07/17/14 11:46 PM
Re: 67 tail light bolt installation 68tpls400 07/18/14 12:11 AM
Re: 67 tail light bolt installation tbarsch 07/19/14 01:31 AM
