In between fighting with the brakes I worked on a couple of bugs in the interior. As ALL the courtesy light bulbs were missing. Traced wires, all looked good so didnt understand why there were no bulbs. installed new bulbs Bam all lit up...... Then Shut the door and they stayed on. Ok Now I know why they were no bulbs in..... Im sure you guys know how to fix it. After a few minutes scratching my head easy deal just adjust the springy push pin thing (not sure what they are actually called). all good go on and off as they should with the door open as well as the light switch.
Interior 95% done. just a couple odds and ends. will finish that tomorrow while taking a break from the brakes!
