K
K Offline
Originally Posted By Bluebird428
Is that a steel braided line from the pump up to the filter fittings?
Looks like you still have to put your rad hose and thermostat housing on. Do you have the rest of the components attached up front? You might want all that on before routing the fuel line.
I had the same manifold with a spacer and it had clearance. I now have an RPM manifold, there's just enough clearance to have the filter on the inlet tube.
Like Bob says, you may be able to slightly bend the inlet tube if it can't be loosened and rotated up a bit to eliminate the fitting chaffing on the manifold.
Bluebird- It is a steel braided from the pump and you are right about the hoses, therm housing, etc. not on. I've been trying to do a dry run on the line first. But, as you suggest, I will hook up all of the components before fully routing the fuel line. Thanks again for the help.
Bernie
1969 Firebird Convertible
Aftermarket Fuel Line Question Keydet86 12/17/14 12:48 AM
Re: Aftermarket Fuel Line Question salmon38 12/17/14 01:29 AM
Re: Aftermarket Fuel Line Question Keydet86 12/17/14 01:55 AM
Re: Aftermarket Fuel Line Question salmon38 12/17/14 02:27 AM
Re: Aftermarket Fuel Line Question Keydet86 12/17/14 02:43 AM
Re: Aftermarket Fuel Line Question Bob S. 12/17/14 03:53 AM
Re: Aftermarket Fuel Line Question Keydet86 12/17/14 04:51 AM
Re: Aftermarket Fuel Line Question Firebob 12/17/14 04:58 AM
Re: Aftermarket Fuel Line Question Keydet86 12/17/14 11:14 PM
Re: Aftermarket Fuel Line Question goose919 12/17/14 05:46 AM
Re: Aftermarket Fuel Line Question Keydet86 12/17/14 11:17 PM
Re: Aftermarket Fuel Line Question glider 12/18/14 05:34 PM
Re: Aftermarket Fuel Line Question Keydet86 12/18/14 11:54 PM
Re: Aftermarket Fuel Line Question Bluebird428 12/17/14 04:28 PM
Re: Aftermarket Fuel Line Question Keydet86 12/17/14 11:26 PM
Re: Aftermarket Fuel Line Question Hansee 12/17/14 06:11 PM
Re: Aftermarket Fuel Line Question Keydet86 12/17/14 11:37 PM
Re: Aftermarket Fuel Line Question Firebob 12/18/14 02:57 AM
Re: Aftermarket Fuel Line Question Keydet86 12/18/14 05:37 AM
Re: Aftermarket Fuel Line Question Bluebird428 12/18/14 04:48 AM
Re: Aftermarket Fuel Line Question Keydet86 12/18/14 05:55 AM
Re: Aftermarket Fuel Line Question Bluebird428 12/18/14 04:51 AM
Re: Aftermarket Fuel Line Question Bluebird428 12/18/14 03:28 PM
Re: Aftermarket Fuel Line Question Bluebird428 12/19/14 05:00 AM
Re: Aftermarket Fuel Line Question Keydet86 01/07/15 04:00 AM
Re: Aftermarket Fuel Line Question salmon38 01/07/15 02:50 PM
Re: Aftermarket Fuel Line Question Keydet86 01/08/15 03:10 PM
