The problem is I don't even know how much can be milled off. The piston comes right to the top already. Ive seen worse on boat engines and they use jb weld and aviation seal. they run fine, but was going to build a good 500hp engine out of this. (or as close as I could get with out major investment)
Not sure if I can use high comp pistons now let alone build this block
-Greg
Pontiac Block deck pitting - How bad is too bad? GregB. 03/01/15 01:58 AM
Re: Pontiac Block deck pitting - How bad is too bad? Bluebird428 03/01/15 03:29 AM
Re: Pontiac Block deck pitting - How bad is too bad? GregB. 03/01/15 03:46 AM
Re: Pontiac Block deck pitting - How bad is too bad? GregB. 03/01/15 03:47 AM
Re: Pontiac Block deck pitting - How bad is too bad? bigchief 03/01/15 07:25 AM
Re: Pontiac Block deck pitting - How bad is too bad? GregB. 03/02/15 03:32 AM
Re: Pontiac Block deck pitting - How bad is too bad? GregB. 03/01/15 03:14 PM
Re: Pontiac Block deck pitting - How bad is too bad? GregB. 03/01/15 03:15 PM
Re: Pontiac Block deck pitting - How bad is too bad? bigchief 03/02/15 05:09 AM
Re: Pontiac Block deck pitting - How bad is too bad? Firebob 03/02/15 04:46 PM
Re: Pontiac Block deck pitting - How bad is too bad? GregB. 03/06/15 03:25 PM
Re: Pontiac Block deck pitting - How bad is too bad? GregB. 03/03/15 03:04 AM
Re: Pontiac Block deck pitting - How bad is too bad? Bluebird428 03/03/15 04:02 AM
Re: Pontiac Block deck pitting - How bad is too bad? GregB. 03/05/15 04:26 PM
Re: Pontiac Block deck pitting - How bad is too bad? bigchief 03/03/15 04:59 AM
Re: Pontiac Block deck pitting - How bad is too bad? GregB. 03/05/15 03:58 PM
Re: Pontiac Block deck pitting - How bad is too bad? bigchief 03/05/15 05:45 PM
Re: Pontiac Block deck pitting - How bad is too bad? Bluebird428 03/05/15 04:59 PM
Re: Pontiac Block deck pitting - How bad is too bad? GregB. 03/05/15 05:28 PM
Re: Pontiac Block deck pitting - How bad is too bad? wovenweb 03/05/15 08:28 PM
Re: Pontiac Block deck pitting - How bad is too bad? bigchief 03/06/15 04:44 AM
Re: Pontiac Block deck pitting - How bad is too bad? wovenweb 03/06/15 04:52 AM
Re: Pontiac Block deck pitting - How bad is too bad? GregB. 03/06/15 03:22 PM
Re: Pontiac Block deck pitting - How bad is too bad? bigchief 03/06/15 06:52 PM
Re: Pontiac Block deck pitting - How bad is too bad? Bluebird428 03/07/15 06:43 AM
Re: Pontiac Block deck pitting - How bad is too bad? bigchief 03/07/15 09:15 PM
Re: Pontiac Block deck pitting - How bad is too bad? 4dabird 03/08/15 04:10 AM
Re: Pontiac Block deck pitting - How bad is too bad? Firebob 03/08/15 07:48 AM
