One word of advise when it comes to replacing the springs as I went through 3 changes the past year! As I'm sure you know the springs will set the stance/ride height in front. It depends heavily on what your rear springs are doing...worn or raised rear end. If you get stock replacement coil springs and your rear springs are stock...AND you like the stock ride height you're good. If you're like me and have the rear slightly higher than stock and run 15" wheels you might want to add a spacer under your coil springs or get Eatons 1" taller that stock. Just my 2cents.
