I have seen air shocks on 2 firebirds and in each case the car had a broken leaf spring.
The air shocks worked well at balancing out the rear suspension. If you need to raise or lower rear end for what ever reason these shocks will do it.
However, you effect the handling of the car. The ride will be stiffer and you will have less travel on your shock absorbers. The farther you go up with the air shock the less travel for shock absorption.
Personally, I would only use air shocks if my rear suspension has been weaked or I have an increased load affecting my ride height.
