why would you put the relay at the back neer the pump, you just have to run more wires all the way back there with more chances of them getting damaged and shorting out. I mounted mine up front and then you only have one wire to run to the pump. Has been on my car like that for 40 years with not one problem. Just make sure you use a little bigger wire for the pump than what is recommended, and use inline fuses
