K
K Offline
I have looked at the wiring and the resistor is bypassed for a direct 12v when on high. I’ll direct wire and see if I can isolate the switch. I have never worked on the switch but I imagine I will have to pull the dash. Any tricks to this as I assume it is a PITA.
Blower motor works in high when first started but stops after 30 seconds Kenttab 10/14/19 01:24 AM
Re: Blower motor works in high when first started but stops after 30 seconds Kenttab 10/15/19 01:53 AM
Re: Blower motor works in high when first started but stops after 30 seconds salmon38 10/15/19 11:14 PM
Re: Blower motor works in high when first started but stops after 30 seconds hokie1984 10/16/19 12:54 PM
Re: Blower motor works in high when first started but stops after 30 seconds Jimc2002 10/16/19 02:32 PM
Re: Blower motor works in high when first started but stops after 30 seconds Ronnie S 10/17/19 05:48 AM
Re: Blower motor works in high when first started but stops after 30 seconds hokie1984 10/17/19 01:27 PM
Re: Blower motor works in high when first started but stops after 30 seconds Kenttab 10/20/19 04:33 AM
Re: Blower motor works in high when first started but stops after 30 seconds Ronnie S 10/21/19 05:56 AM
Re: Blower motor works in high when first started but stops after 30 seconds Bob S. 10/21/19 10:42 AM
Re: Blower motor works in high when first started but stops after 30 seconds Kenttab 10/20/19 04:28 AM
Re: Blower motor works in high when first started but stops after 30 seconds Gus68 10/18/19 06:23 AM
Re: Blower motor works in high when first started but stops after 30 seconds maxepr 10/20/19 01:06 AM
Re: Blower motor works in high when first started but stops after 30 seconds Kenttab 10/20/19 04:31 AM
Re: Blower motor works in high when first started but stops after 30 seconds Kenttab 10/20/19 04:25 AM
