Posts: 48 |
I made one for my OHC with a long bolt that I cut the head off. I then used a grinder to shape the end. The V8 distributor looks similar to the OHC so it should work. Use a slightly smaller diameter so it doesn’t rub the walls. ok, if no one comes up with a part number, that sounds simple enough!
0 members (),
1,611
guests, and
74
robots. |
Admin,
Global Mod,
