Hi! I'm having the rear differential on my 68 vert redone at a local shop. I've looked at previous posts discussing gear ratios, etc. I plan on having a standard 400 build with just a little more punch, correct turbo 400 auto, with AC. I'll be doing highway driving and around town on 15" Rally II rims with 235 or 245 60's all around. I know tire height makes a difference. I'm thinking 3:36 or 3:42 gears with a posi carrier. I think 3:55 would be too high. Stock was the 2:56 open. Any huge difference between the 3:36 and 3:42? What manufacturer do you all most recommend? Auburn, Dana, Yukon, Eaton?? Appreciate the feedback!
I had my tranny builder beefup my TH400 with better/stronger stock components and a shifter. You can you the stock shifter for the wholesome look or after market one. Either way your going to bury the guy with the 4sp standard. My 400HIO has A/C as well and thus came with 2:56 gears. The owner replaced the 2:56 with 3:91 and turned of the A/C. I bought the car and played with the 3:91 ripping up the pavement. Lot's of fun for a summer, but not practical for old farts. I have my 3:42 Posi available so I'm going to use it as I sold the 3.91. I think it will be a good combo. Make sure you use the stock Qjet and your ready. IMO, get 3:42, I'd be pissed if the engine booged on 1st jear with 3:36
