J Offline
Check the throttle spring
When I had the surge issue it was the throttle.
The spring setting had throttle partial open so when you shift the throttle surges.
Engine "surges" in all four gears after replacing carb nashville68bird 02/07/21 12:14 AM
Re: Engine "surges" in all four gears after replacing carb Bob S. 02/07/21 02:58 PM
Re: Engine "surges" in all four gears after replacing carb nashville68bird 02/07/21 05:30 PM
Re: Engine "surges" in all four gears after replacing carb Bob S. 02/07/21 05:47 PM
Re: Engine "surges" in all four gears after replacing carb Dr. Drivability 02/07/21 05:59 PM
Re: Engine "surges" in all four gears after replacing carb nashville68bird 02/07/21 07:54 PM
Re: Engine "surges" in all four gears after replacing carb JCK68 02/08/21 01:37 AM
Re: Engine "surges" in all four gears after replacing carb uconn86hgiv 02/08/21 08:17 PM
Re: Engine "surges" in all four gears after replacing carb Frankie1968 02/09/21 04:02 AM
Re: Engine "surges" in all four gears after replacing carb nashville68bird 02/09/21 08:51 PM
Re: Engine "surges" in all four gears after replacing carb nashville68bird 02/10/21 11:32 PM
Re: Engine "surges" in all four gears after replacing carb JCK68 02/11/21 03:44 AM
Re: Engine "surges" in all four gears after replacing carb uconn86hgiv 02/11/21 04:59 PM
Re: Engine "surges" in all four gears after replacing carb nashville68bird 02/11/21 06:12 PM
Re: Engine "surges" in all four gears after replacing carb Sleddog 02/15/21 05:27 PM
Re: Engine "surges" in all four gears after replacing carb nashville68bird 02/17/21 08:29 PM
Re: Engine "surges" in all four gears after replacing carb Amervo 02/20/21 03:57 AM
Re: Engine "surges" in all four gears after replacing carb Pci_raid 02/28/21 02:05 PM
Re: Engine "surges" in all four gears after replacing carb Frankie1968 03/01/21 03:48 PM
