N
N Offline
Guys that have mentioned the throttle spring here...are you referring to the simple spring on the drivers side of the carb that provides tension to the throttle linkage? Having a hard time understanding that would cause a problem. You saying maybe the spring is too weak and therefore allowing a weak tension while driving?
Engine "surges" in all four gears after replacing carb nashville68bird 02/07/21 12:14 AM
Re: Engine "surges" in all four gears after replacing carb Bob S. 02/07/21 02:58 PM
Re: Engine "surges" in all four gears after replacing carb nashville68bird 02/07/21 05:30 PM
Re: Engine "surges" in all four gears after replacing carb Bob S. 02/07/21 05:47 PM
Re: Engine "surges" in all four gears after replacing carb Dr. Drivability 02/07/21 05:59 PM
Re: Engine "surges" in all four gears after replacing carb nashville68bird 02/07/21 07:54 PM
Re: Engine "surges" in all four gears after replacing carb JCK68 02/08/21 01:37 AM
Re: Engine "surges" in all four gears after replacing carb uconn86hgiv 02/08/21 08:17 PM
Re: Engine "surges" in all four gears after replacing carb Frankie1968 02/09/21 04:02 AM
Re: Engine "surges" in all four gears after replacing carb nashville68bird 02/09/21 08:51 PM
Re: Engine "surges" in all four gears after replacing carb nashville68bird 02/10/21 11:32 PM
Re: Engine "surges" in all four gears after replacing carb JCK68 02/11/21 03:44 AM
Re: Engine "surges" in all four gears after replacing carb uconn86hgiv 02/11/21 04:59 PM
Re: Engine "surges" in all four gears after replacing carb nashville68bird 02/11/21 06:12 PM
Re: Engine "surges" in all four gears after replacing carb Sleddog 02/15/21 05:27 PM
Re: Engine "surges" in all four gears after replacing carb nashville68bird 02/17/21 08:29 PM
Re: Engine "surges" in all four gears after replacing carb Amervo 02/20/21 03:57 AM
Re: Engine "surges" in all four gears after replacing carb Pci_raid 02/28/21 02:05 PM
Re: Engine "surges" in all four gears after replacing carb Frankie1968 03/01/21 03:48 PM
