Temperature light operations and flickering help.
Re: Temperature light operations and flickering help.
Ron1967
330658
07/26/21
05:09 PM
Jan 2009
Elk Grove, California
Jan 2009
You tested the temp sending unit correctly.
And no, it does not come ON with the key ON. Only the GEN and OIL lamps should come ON with the key ON.
As far as the flicker goes, disconnect the alternator and then start the car up. If the flickering stops, you've found the issue.
The door switch issue, sounds about normal to me - Wouldn't be too concerned with it.
-Jeff
Subject
Posted By
Posted
Ron1967
07/25/21
11:17 PM
Ron1967
07/25/21
11:33 PM
09:09 PM
Ron1967
07/30/21
09:39 PM
Ron1967
11/06/21
06:35 PM
Ron1967
11/07/21
07:26 PM
Sleddog
11/08/21
07:23 PM
1stgenbirdman
Switch to Flat Mode
0 members (), 506 guests, and 18 robots.
RLMOORE
