-My seatbelts in the back (not in picture), is also brand new SUBARU, -they are practcally invisible, -as you have two points that you 'click' in the bottom, and the roller is mounted (roller has two 'keys') underneeth the rear spreker/window tray..-you pull down the seatbelt from upper left or right side, and click it two places..
-The front mounting point actually goes through the inner door jamb, (only a bottomhead bolt is visible (painted))
