Ok lets start out with all the issues I have found.
-Brights are always on, replaced switch. -Fuel guage always reads empty. -No dummy lights are working.
Facts
-Ignition lock on the column is sloppy and the key can be removed while in the on position, if you do not make sure the cylinder is in the lock position it will drain the battery. -Someone had an alarm in the car at one time, the wiring has been altered but from what I can tell only splices which have been removed. -The only fuse not installed is the lighter fuse.
