Removing brake drums on a 69
Re: Removing brake drums on a 69
M1Bully
70456
01/14/07
11:46 PM
Sep 2001
Michigan
Valued Mentor
Valued Mentor
Sep 2001
Michigan
Here is a link to a page with a lot of do-it-yourself brake information including drum removal. It will help with the rear drums.
http:/
www.partsource.ca/
doityourself/
JOM_May2005.asp
If you have drums on the front, the drum comes off after removing the bearings. Here's a link to an illustration.
http:/
209.237.45.104/
illustrated/
front/
front1.html
On either front or rear you will need to get to the star adjusting wheel so that you can back off the shoes. There is an access hole in the backing plate right behind the star wheel.
Subject
Posted By
Posted
M1Bully
01/15/07
03:19 AM
03:46 AM
1stgenbirdman
Switch to Flat Mode
0 members (), 391 guests, and 20 robots.
Highlander
