The vacuum advance connects to ported vacuum. To check the vacuum - feel the vacuum hole on carb. if it gets no vacuum at idle but starts to get vacuum if you rev it then thats the ported vacuum. I Beleive the brakes and transmission can be connected directly to the intake manifold which is manifold vacuum, vacuum at idle, though i'm sure the carb has some manifold vacuum ports on it.
