The threaded rod (use hardened alloy rod) method seems to work the best. Use 1/2" threaded rod through the shock holes. Most of the spring compressors won't fit in the springs well enough. I've changed mine that way, although all the front sheet metal was off at the time.
-=>Lee<=- Due to budget constraints the "light at the end of the tunnel" has been turned off!
