I don't know why my last topic stays on the top list for so long but I feel kinda important. Anyhow does anybody know if all 4-speed Sprint models come with a 3:55 posi Nodular rearend? Please pass the buck. Thanks Dan Zordon316@aol.com
the rear gear could be ordered in a number of ways depending on other equipment such as A/C. A 3.55 diffy could be a factory configuration with the 4spd. My base cammer 1bbl 3spd column shift came with a 3.55 diffy. And I'm glad it does, for it helps with getting this 'bird under way.
It may be a 3:55 but that is standard 1 brl. does the Sprint get a beefier posi Nodular? Any info would be Great and I am mostly talking about the 1967 Firebird but would be curious about the rest of the 68 and 69 series. Thanks
nodular would be a higher alloy cast iron center section. stronger form of grey iron to withstand destruction from the drive train due to higher H.P. from the engine!
Andy
Nodular iron is a more ductile (less brittle) form of cast iron due to special processing and chemistry control that results in the graphite being in spherical nodules instead of flakes.
