Replace the specific areas on your quarter panels that are rusted with Classic Industries replacement patch panels. These superb quality replacement panels are manufactured in the USA and designed to allow you to replace sections that are rusted or dented without replacing the entire panel! When rusted areas begin to appear, you'll be able to solve the problem fast and easy by replacing the affected area. Each section is designed and manufactured to allow installation of the original wheel opening moldings and includes an offset edge for easy installation. Why buy full quarter panels when you don't need them! Once installed correctly, your quarters will look new again!
Restore your old rusted quarter panels with this unique patch panel kit. An inexpensive way to replace rusted wheel openings without the high cost of purchasing new quarter panels. Each kit comes complete with two panels to completely replace the entire outer wheel opening section. All panels include the correct lip to install the wheel opening moldings. The panels also include an offset flange making installation easy! The front and center patch panel measures 17 high x 45 long and the lower rear section measures 15-1/2 high.
Important: The front portion was originally manufactured for the 1969 Camaro. The Firebird front panel does not include the same louver pattern. Adjustments to the sheet metal will be required to install on Firebird models.
Note: This item is shipped via UPS oversize.
Si Vis Pacem Parabellum
