did firebirds come with 12 bolt rearends because i have a 12 bolt under my 68. if firebirds were not equipped with 12 bolts, where could this rearend have come from? are camaro and chevelle rearends interchangeable with the 68 firebirds? thanks for the info.
I believe that none of the first generation Firebirds came with 12 bolts. That was a Chevy thing. (The 6 cylinder, and low HP V8's got the 10 bolts, the higher HP V8's got the 12 bolts.)Pontiac used their 8.2 " 10 bolts with all engine options.(from 1bbl OHC 6 to the Ram air 4 400)(Pontiac beefed up the rear axle with a heavier differential on the higher HP engines)If you see a First gen with a 12 bolt, it has been switched........
is it common to see firebirds with 12 bolts, or should i say switched to 12 bolts? would it be a sin to keep the 12 bolt under my bird? :rolleyes: and how hard is it to find a 8.2" 10 bolt for my firebird? thanks.
