Unless they've gone down a lot since last year they were over $1000 for the Pontiac kit. Someone else was making a serpintine system as well but I can't remember where I saw that.
500.00 sounds ok 1000.00 sounds a bit much sent march a email for price we will see. drew67 i have lots of heads for sale lol or i recive some money from some one lol
They are $400 without power steering and $600-650 with power steering. Add AC and they're upto $1000. Rodney Red is the other manufacturer. RR is a little less because they use steel brackets instead of billet pieces. I have some pics on my website below.
John what a nice job you have done with your bird im impressed. nice site Thanks for the info i will be checking with them tomorow .glad i dont have ac lol power stering is a must. i will get prices from both companys but for my 455 i think its the way to go. Thanks again
As an alternative - you can get a set of billet aluminum pulleys that will work with the OEM fanbelts from Ram Air Restorations.
if the car originally came with v-belts,you should put a serpintine belt system on it.and new cars with a serpintine belt,should be converted to v-belts.don't that make sense?
Thanks. I really didn't know. I figured it had to be more than simply space savings. Multiple belts never would fit in my sideways LS4 V8 GP so I could only think of that need.
They're supposed to free up a little horsepower, but I'm sure you could add additional HP for less. I think the main advantage is cleaning up the front of the engine.
