I need to replace teh gasket that goes inbetween the interrior and engine compartment portions of the fuse block. Any idea on where to get one or what else could be used? Also, any specifics on teh dielctric grease used?
I Didn't see anyone selling the gasket, so used a thin coat of clear silicone sealant. You may be able to make one from a piece of home weather stripping.
I got a gasket with my new main wiring harness, but I would not be surprised if it does not come separately.
