I bought a rubber front end kit, front and rear sway bar and 4 KYB shocks. I was very happy with everything. Free shipping and the assembly was straightforward.
I bought a complete kit for a '68 convertible I used to own. I also had a good experience with PST. The whole process was pretty simple, except for getting the coil spring in and out - that is a little tricky because the top of the spring is inside the upper sub frame.
I bought a video that showed how to rebuild the front end of a car and it was extremely helpful. They did a GTO but most of it is basically the same.
Parts are OK, I have heard several complaints over at the Classical Pontiac board about a lack of customer service if you have a problem.
I'm partial to Performance Suspension Components myself as they not only supplied the parts I needed, but worked with me to develop poly bushings for my factory traction bars.
