Would anyone have a decent photo or two of the area where the end of the frame rail and underside of floorpan join (69 coupe). I need a little clarity on how things go together. My rusted out floor had no bolts holding the spring eye in the cup when I got it, just haywired and tack welded in place.
the bolt goes through the bracket from the outer side of the car. then the spring eye pocket mounts up to the car. it makes for a fail safe in case something were to happen to the bolt.
Andy
