I have my headliner just about totally installed, but I have a few questions.
#1. In the front windshield area, I have the headliner wrapped over the windshield lip and the metal trim pieces holding it down. The metal trim holds the headliner down nice and tight on the interior side, but there is a gap between the trim piece and the windshield lip on the window (front) side. Is there a rubber trim piece that gets sandwiched in there?
#2. In the back window area there is a metal trim piece (similar to the front) that holds the back in. How does this get attached? It appears to have special clips? Where can I get them? I have a completely new roof, will the mouting holes still be there? I have an OER rubber trim piece for the back. Does this go over the window lip?
1. There's a trim piece that fits right over the front edge of that front hold-down. It has a 'cut-away' section in it for the rear view mirror. 2. There are metal spring clips that 'snap' into the holes. They always get ruined when you pull that piece off. I think Ames has them. I've been in a hurry and bought plastic clips from the dealership that you can get by with. Either way it's slightly difficult to get them to snap in. If those holes are not there on your new roof then you can use the metal retainer piece as a template to drill new holes.
