Sorry, i guess i blew it. i have the stacked type of gauges in my 69, not the rallys as i thought they were called. they are original to the car. will this make any difference to the help you guy's gave me? or is trouble shooting them the same as the rallys? So, what are these gauges called? and if i could figure out how to put the icons on, i would have put all the stupid ones on this! sorry again, mark
I just re-did mine. I'll see if I can find the pics of the ground straps on the back of the dash. Have you checked all the fuses? Maybe just replace them all even if they look good because sometimes it's hard to tell and easy enough to give it a try.
I was wondering if you could give me the wire colors on the 12 pin connector for your stacked guages, because I'm converting and I don't know exactly how to run the wires. I'm converting from rally to stacked. Thanks Tyler
