cant see pics from here at work,only a little rex 'x', but will check at home later...but I assume this is the Camaro 'snow plow" as I have.... 3 rods (brackets) to install with?
We drilled and tapped the middle one , the other attaches in the screw holes for the front valance... hope this is what you`re asking about...
sorry about the dirty underside , but I do drive my car and pics were taken long after installation..
ok checked at home and you had no picture....just your car, that was the red "x", so I guess mypics shuld be ok, since I assume you bought the "snowplow" w brackets
and some people say 'dont use the brackets', but if you tend to drive 'fast',at instances, you will want them,I`ve had friends` spoilers break off (w/o brackets)
