Hi Doug, yes, I have built my own, and have pix.. (I should put them on a page some place to make it easier, as I'm sending them all the time...)
I also should take some better pix!
Anyway, send me your email, and I can send you a couple of pictures, and get you more information.
These are built for a convertible, and for the most part are overkill. 2" 1/8" thick square tubing, with a notch cut in for the vert cross brace, and in my opinion too thick of a spring plate. I would step down in material thickness if I were doing it again.
Anyway, just let me know! - Brett - 67 Drop Top 455! brett@cisdirect.com
hey Doug try contacting Carl Casanova here is his web Page Scroll down to see how he made his he explains everything subframe connectors your friend, joe
The ones I built can be installed with out making them permanent, and or with out much modification and are for my Vert, which gets you into even more complications with the extra bracing under there...
Doug, you have mail!
Mark, send me your email... I'll get better pix soon Guys, and will make measurement specs too. I'll try th get the time to put this all up on a page at some point in the near future!
