#124523 03/12/08 07:14 PM
Are the water pumps still available with the cast impeller? Any ideas who has them? The local parts stores here can only get the type with the metal impeller....
Thanks,
Fuhrmann #124524 03/12/08 07:26 PM
I ordered one from Ames and had the person on the phone go back into the warehouse to confirm it had the cast impeller.
I heard rumors from either the PY or Classical Pontiac boards that you can go to NAPA and roll the dice. My next door neighbor is the sale manager for the only NAPA in town and he got one in as a favor. It had a stamped impeller so I went to Ames.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
salmon38 #124531 03/12/08 08:32 PM
You can buy them brand new, manufactured by GMB, for the 11 bolt. Cost < $50 and carried by many local auto parts chains. Just call around.
I do not know if GMB has rebuilt ones, or if they do if they have cast impellers. I know the new ones do.
Vikki
Restoration Gallery
http://thefirstgensite.com
salmon38 #124532 03/12/08 08:36 PM
I ended up getting a rebuilt pump for the cast impeller. Ordered 4 and saw a number of different impellers. I found the one I wanted. It even had an aluminum housing. I pounded the plate out and ended up with about .030" at the innermost part. ('69 type cover)
greg fielder #124554 03/13/08 01:49 AM
E
E Offline
Forgive my for asking but how much difference/advantage etc. does the type of impeller have? Stronger I am guessing? Or do they move more water/flow better???
#124593 03/13/08 03:01 PM
I read a thread recently on the PY forum. Some one had a part # to use that garenteed a cast impeller. I think it was for Napa?
rohrt #124597 03/13/08 03:11 PM
I have to think the cast impeller will flow more water. I had tried the plate trick with a stamped impeller, and that didn't have as much impact on summer running temperature as the cast impeller. From the ones I selected from, there were at least two different cast impellers too. So even they are not all created equal.
greg fielder #124615 03/13/08 06:52 PM
Which would you choose?:
Bronze Bird #124616 03/13/08 07:08 PM
Kind of a no-brainer when you put it like that....
68tpls400 #124618 03/13/08 07:25 PM
Maybe not....
I use the non-cast pump on the left. The cowl on the impellor blades accomplishes the same thing as the "divider plate" trick. Its been working quite well for about a year...
I don't see how the 6 blade cast impellor would move more water that the 8 blade welded.
Bronze Bird #124623 03/13/08 08:06 PM
Now thats a thought. So do you still use the o.e. plate even with the modification? If not, what holds the sleeves (in the timing cover) in place? Wait...that is the 8 bolt pump.
greg fielder #124625 03/13/08 08:32 PM
Napa was able to bring in a remanufactured unit for me and it had the cast impeller! Also the correct date code and casting number as a coincedence! I have heard people who try the stamped 11 bolt have problems... I'll stick with the original design!
Fuhrmann #124626 03/13/08 08:35 PM
My car has a stamped steel impeller waterpump. No over-heating issues.
Bruce
'67 Firebird Convertible
Bronze Bird #124628 03/13/08 08:51 PM
Just from a similar experience with a different auto maker, the 6 blade will move more water at higher speeds due to it's ability to more completely fill the impeller area.
I wonder if there is a 6 blade with a plate like the one on the left out there? I would think it would be as good or better due o a thinner wall profile.
But maybe I am thinking the speeds are higher than they truely are in these cars. Does slowing the water pump speed help?
Dave
New to me '68 Conv. 350. 2 Speed. Red on Black.
455 on the stand getting ready to bolt up to a TH400.
N
N Offline
Bronze, you know which aftermarket WP I use on the new 428 HO M3 engine. No divider plates or other parts and measurements to worry about. All is well after 12 months and 5K.
So, there's 2 of us so far.
Bronze Bird #124723 03/14/08 04:13 PM
There is a relationship as you want to give the coolant enough time to be cooled in the rad as if gets pulled through too fast it doesn't have the time to let off the heat. becomes a problem when running a aluminum rad as it is more efficient and typically you have to draw the co0lant through it faster!
