OK im doing the 350 to 2004r swap, forgot to ask, does anyone know if the rear mount for the 350 is in the same location as the 2004r, i just dont wanna buy a 220.00 new crossmember, ive checked the web site and they list 400 to 2004r, i know same lenght and bell but very curious on mesurement,. thanks
I had the TH400 cross member and it worked fine as the bolt hole locations are concerned. I came accross it at a swap meet, IF you have the time. In '76 when I took the ST300 (two speed) out and put the TH400 in, we made a cross member and it worked quite well. It was much later that I came across the proper 'member.
You need a 400 cross member But you should be able to pick one up for around $100. I swapped a 350 for a 2004r a few years ago, It worked out great, I was able to use the same drive shaft. I later went from a 355 to a 390 and the car has everything I want.
The price for the reproduction pieces is about $80. I heard they are good quality-wise. Most of our typical repro parts places (Ames, CI, PY) have them.
