I bought this from Classic. It says you need it for the deluxe door panels. I dont see any holes in the inner door that it would line up with?? Any pictures???
Thanks
1967 400 Convertible 1978 Firebird 1980 Trans Am Pace Car (Sold) 2002 Ram Air Convertible (Sold) Mike
see the handle has 4 holes, you'll end up using one of the round hold for one screen and the other screw will line up with the other cross horizontal hole. Let me see if I can get you a pic today.
Yeah, I tried to make a wrench like that this past weekend without heat. Had a vice grip and a rubber mallet... Needless to say, my wrench now no longer has the closed end on it. But it actually worked out okay.. It made the wrench short enough that I was able to get in under the doorhandle and tighten the screws. It took forever because each turn was probably 1/8th of a turn, but it finally got done...
oh and just wait until you have the pleasure of installing that lil $@#&*%! screw that holds the deluxe door handle onto the shaft..
Finally got it all together. However I don't have those screws. Any ideas as to the size and thread specs, so I can get some?? Or are they specialty items ($10 each from classic? LOL)
I could not find them for sale anywhere and they are completely out of sight, so I just went to Lowes and purchased a couple of screws with 1/4" heads on them since I found that it was impossible to get a screwdriver down there.
I want to say that the thread size was 8/32 or something to that effect and I think I used either 1/2" or 3/4" screws.. I just purchased them last weekend and put them on last weekend and Im drawing a blank. I would carefully thread some test screws into the hole while it is apart to get the proper size as that is what I did. But the only way I was able to get the screws in once the handle was in place was with a 1/4" wrench and a great deal of time, frustration, and swearing. I would have included a beer or 2, but then that would have made me have to add even more time, frustration, and swearing. So I had the beers after I was done.
I just took mine off yesterday. I have the screws at home. PM me a reminder and I will measure them for you.
It was a black screw with a 1/4" head, about 3/4" long.
Craig
