#133459 05/23/08 02:40 AM
E
E Offline
Ever get to that point where you just want to scream and bang your head against a wall? I'm there. I got the old pinion and ring back in the bird, but decided to use the new crush sleeve. Well... trying to get that thing to crush, stripped the pinion nut. So... try the other pinion nut from the wrong pinion since they're threaded the same... going good... and bam. Strip that sucker too. Anyone have any ideas, because I'm about to go insane in the membrane.
It's probably not the nut's fault. I bet the socket is the culprit now. Get a new nut and a new socket and try again. You can put extra washers on for the crush to get that nut out there where the socket can grab it better.
Every freakin day in the garage lately.
BTW, hello Elizabeth!
I put a little padding on my spot on the wall and the beer fridge next to it. That way it's "Bang*Pop*Fizz" instead of "twitch*twitch*fizzle laugh
David
68 Droptop 400 4 spd.
E
E Offline
Didn't strip the head, just the threads. Anyway, went to the chevy dealership in town and picked up TWO nuts, just incase we stripped another. Got it all put together, and it's up and running saweeeeeet now. Also managed to find a buyer for the wrong gears since we couldn't find the box they came in and the company refused to take them back, so that was pretty awesome too. Will put some pictures up in about 20 minutes.
My pain from this week is going to last quite a while.
Got my new 455 finished in Feb. Mounted it nice and easy with the tranny attached on a bare subframe. Spent the past couple of months slowly putting the front half of the car back together. A few trials, some customizing, but it ran and I was this close to having it legal for the street. 10 years this car has been off the road.
Decided to take it around the block Thursday. Open headers so I took it slowly. It's probably the 4th time I've had it running.
I blew out the rear oil pan seal. The friggin motor has to come out again.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
Nice to get a hard job finally done...good on ya girl!
David
E
E Offline
*grimace* That suuuuucks.
Old or new style pan and gasket?
When you have it out, let me know what happened.
May have a few tips for you.
My car hates me...
FWIW, i've been fight'n a shift linkage issue since last year.
Decided last night to make my own lever(attaches cable to trans).
Every one i've tried either wont go all the way from park to low.
Or from reverse to drive select has a wrong throw.
Or park to reverse/neutral.
Or from drive, to 2, 1.
Or...
mad
My car hates me...
Poncho -
Milodon OEM replacement pan. "3-tab" rubber rear seal. It bulged out between the middle and a side tab.
This fix is going to have to wait for quite a while. I emptied my "Firebird Fund" getting the car running and I am in no hurry to revisit all the little challenges I had getting the motor in. Besides, I am probably relocating again this summer.
Gas prices are much of an incentive now, either.
It's time to put this project on the back burner again.
1980 Turbo Trans Am
Here's a pan seal trick to avoid bulging out;
Use a continuous bead of silicone gasket sealer on both sides of the gasket. Install the pan and just barely snug up the bolts. Wait at least 24-48 hours before re-torquing. The seal shouldn't squeaze/bulge out that way.
E
E Offline
RTV (room temp volcanizing (sp?)) is vundervah!
