Hopefully someone has there dash out and can help with a pic. I need a picture of the back of a 69 dash that still has the instrument cluster and ground pieces connected. Thanks,
Thanks Jim. That helped some, I'm guessing if you have a clock delete plate then the ground screw above the lighter is not used. Also I have 2 small metal brackets that have a piece turned up on the end with a screw hole. Anyone know where they go?
