I was needing to know the length and size of the transmission cooling lines? The transmission is a TH400. Does any one know where to get new line already pre-bent? Thanks!
i think classic sells pre bent. prob'ly the other mags too.
or try http://inlinetube.com/ , they've got some neat stuff. maybe not pre-bent for transmissions though.
i think they're supposed to take 5/16" line like the other transmissions, but i did do a th400 on a jeep which had 1/4" lines with 5/16" adapters factory.
to bend them yourself out of 1 piece per, you'll need a good 6'-8' piece for each tube, i should think.
or you could use shorter sections and splice together inconspicuously, like i did on my 200-4r.
i could only get 5' sections locally, plus i have a cooler, so had to splice anyway.
