Hey guys can you guys tell me what vehicle used this engine...9773153. The is the block casting number. That is all i can see right now maybe later on i can give the date code. I know its a 326 CID from 1964 but what vehicles used that engine is what i am interested in. Thanks Gabriel
There's a three digit code on the front of the block on the passenger side next to the timing cover. The first digit will be a "9." The casting number is definitely a 1964 326 block.
You're just saying that because they never put the 326 into anything else that year. I should have caught that myself. Well, at least with the block code we can figure out how it was built at the factory.
Is that the same as saying it was in a Tempest? The models we had up here in those years were different from yours. And to dispel a myth (conveniently started by some SCCA Trans-Am competitors I'm sure), all Firebirds and GTOs had Poncho engines, not Chevy engines (until the advent of "corporate engines"). I almost bought a 65 Pontiac Parisienne (Grand Prix body style I think) with a factory 409 for $250 way back, and apparently the dual-quad setup was available although I've never even heard mention of one existing.
Hey Quenton where can i check out the specs of the engine..cam, bore, horserpower, torque, ect. I am trying to see if i can just rebuilt that engine for now. Or just sell both my engines wait and buy my 400
so it would be 250 Hp for my two barrel carb.? And would it be 280 hp with a 4 barrel carburator? Thanks for the help Tom. You want to check out some pics that i took of the engine...it is my worst nightmare .
I wouldn't waste any serious time with the 326. All the work and money you will spend on it can be better invested in a motor that will have more currently available parts, and not require you to spend weeks looking for the right starter.
Now, if we were talking about an all-original 326 HO, I wouldn't be saying this. However, I have FIRST HAND experience of buying a 1964 Tempest with a 326, installing a new timing chain set, new cam and lifters, doing a complete valve job on the heads - including new guides, valves and springs and buying a new intake, carb and starter. The one and only time I drove the car was from my house to a junkyard where I got $65 for it, since I had the title. With no title, they would have turned me away.
How true... and just as an FYI the standard 326 usually had #140 heads (lower compression) and the H.O. had #141 heads AND the 4V, hence the nicer HP rating...
But in 1964, the heads were those Banshee described (though I did find a number discrepancy) ... 9773345 for the 2V and 977339(5) for the 4V. (I also found a listing of a 285 HP 4V motor. Not sure which cam it used. May have been a 1965 motor?)
