Anybody have a list of bearings, races and seals part numbers for a 67 Firebird 10 bolt open dif? I took mine apart to check for wear and found part numbers to be non existing and to much wear to re assemble. Looking for pinion, center section and axle numbers.
Can get the parts locally just need the numbers. We get beat up pretty bad with exchange rates and brokerage fees on buying parts from USA so I would prefer to shop on the upper side of the 49th to save a few $ for other parts like Bill Hirsch high temp manifold paint which we can't get here.
Gerry, according to the GM parts catalogue, the Timken part #'s are: Front pinion - M86649/M86610 Rear pinion - HM89449/HM89410 Diff carrier - LM501314 You should be able to get the axle bearings and pinion seal at NAPA or some such. If you have trouble, let me know and I'll get part numbers for those too.
