Silly question, but what holds it in place to the rear. is it some type of pin, or what. pad had small hole to hold it in, but thats it. thanks for any help
I found my spare pedal, and I happened to pick up the linkage/cable assembly from my friend Pat. That's possibly going to Brett.
Anyway, the pedal and spring are attached by the pin. The pin can be removed, by taking the open ends of the spring from around the linkage. Then the pin pulls out. Remember the orientation of the spring, or you'll have a time of it getting everything back together.
I'm having trouble with my server today, so my up and download speeds are really crappy. I'll post pics asap.
Here we go:
