I was reading in the '67 FB factory service manual about the subject item bolted onto the 6 cylinder harmonic balancer to enable raising the engine for motor mount replacement and even oil pan removal. The section for V8 engines gives a similar procedure for replacing the mounts, but makes no mention of using the aforementioned bracket. For motor mount replacement w/ the engine in place, what is the accepted method of raising the V8? At one time, I figured a board under the oil pan w/ a floor jack would do it, but now I'm thinking that may be too far back to work.
Jim Hudson Wooster, OH 1967 Firebird 400 4-Speed Coupe 11,556.7 original miles - some a 1/4 mile at a time
There was an engine lifting loop attached to the water pump. I've never used one to lift the engine, however, as I bolt the hoist directly to the iron heads.
Yes, that loop was used both times I removed and replaced my engine. Mine even bent back toward the flywheel since I used a chain and hoist w/o a leveling cradle. I was hoping to jack up the enginge, rather than lift it, since I don't have ready access to lifts.
